Getting IK To work?
inquire
How do I get IK to work? If I want to move an arm, do I click on the hand And then go To the edit menu, and Select "Enable IK"? Is that supposed to work?
No... Enable IK is activated as default. You just need to select the hand, hit Spacebar to create its IK chain node (Pin Translate / Rotation), then drag the arm to move or dial the rotation properties of the arm to move...
I forgot to mention that I'm using a Macintosh. Is it still just hit the space bar? But I'll check it out.
Ah... I have no idea about Mac, pls further check that out ~~
