Poke throughs
reserv888
I have a mysterious problem (actually two) with poke throughs (Adventure Girl pants).
1. I get poke throughs in the render but NOT in the viewport. I use Iray in the render as well as the viewport.
2. Furthermore I can't get rid of the poke throughs which is annoying. I can fix it in photoshop but I don't think I should have to considering it is a G3 base character with a normal body and G3 clothing.
And yes, I have applied smoothing modifier and I have tried various smoothing iterations.
(See now that there are some (minor) poke throughs on her boots as well.)
I am most curious about why I get different results in the viewport and the render. (Same camera).
Generally, render only poke through is related to displacement settings...usually the min value is pushing the clothing item beneath the skin. You can either raise the min value, apply a push modifier or remove the displacement.
