Black Nipples and Hands When Rendering Iray
in New Users
Hi, for some reason when i am rendering my g2m has black nipples and black hands. In preview they are normal.
I am using Iray.
775 x 778 - 662K
Generally something like that is a wrong shader or settings. If you look at the top of the Surfaces tab there is a line that lists what shader is being used. Select the nipples and see which shader is applied...then compare it to the torso. If the shaders are the same, then right click on the Torso listing (in Surfaces) and select 'copy', then select Nipples and paste to selected.
Repeat for the SkinHand and Fingernails...using the SkinArm surface to check against/copy from.
Are you using Iray-specific materials? Which character is it?
Thank you mjc1016 your method worked for me. The shaders were wrong. So i applied Daz Irayuberbase to all surfaces of the G2M and it fixed the problem.
