characters rotating around a very wide axis
hi,
hope someone can help me with something that i find very annoying and that i run into again and again. sometimes, for some reason (mostly after applying a canned pose i think), when i try to rotate a character on the y axis, it rotates in a very wide circle (so it covers a big distance). hope the explanation is clear, but if not, i attached a file that shows how the crosshairs are removed from the body instead of being immediately below it.
zero figure pose can solve it, but i don't always want to do that. are there other ways?
thank you
1126 x 788 - 49K
The figure has been moved using the hip bone but you are rotating using the figure node. Canned poses should not translate on the hip, bar any y translation needed to keep the feet on the gorund or any offset needed in a group pose, so if it is a Daz product please open a support ticket to report that as a bug. The fix is to zero the hip x and z translations (and possible to rotate using the hip, not the figure, though if the hip has been rotated that can be tricky).
insert the character into a GROUP (create group)
instead the character, rotate the group
most of the time that hapened when you use a pose with "location" it depend how the predefined pose is created.
create group is the easy solution
