Hair
How can you make the hair flow with the movement of the body? (example she;s leaning over the hair should fall down)
  • If this si Daz Studio, morphs, if it's a modelled hair, or by reworking in the plug-in for Garibaldi Express or Look at My Hair. Some hair models have a fairly extensive list of morphs, others have fewer - in any event, a lot of hair is actually mdoelled as several overlapping planes with maps feathering the edges to make it look hair like so there is a limit to how much it can blow or flow - strand hairs (both modelled strands and the procedural systems used by the plug-ins) are potentially more flexible. There isn't, unfortunately, any tool that will calculate the effect of gravity or wind as yet.
  • srieschsriesch Posts: 4,243
    If your hair doesn't have the necessary morphs built in, you might be able to use dformers to some extent.
