Genesis 8.1 Female Left Thigh Bend issue (solved)
felisfelis Posts: 6,648
I have a weird issue with Genesis 8.1 Female.
Selecting left thigh bemd, and trying to move (or type a value) in Side-side results in nothing. Bend and twist works fine. Right thigh works fine.
Genesis 8 Female works fine.
There is no visible things in the parameters.
I have tried both current version and beta, both has same issue.
I have tried to re-install Genesis 8 Essentials, but that doesn't change anything.
A little by random I have an old installation. Loading G8.1 female from there works.
Therefore I am curious if G8.1 female left thigh side-side is working for others.
Or anybody has a suggestion for what the issue might be.
Post edited by felis on
  • felisfelis Posts: 6,648
    edited February 2025
    Afetr some more investigation, it is a controller that is causing it.
    Now I just need to find out which.
    Update.
    It looks like it is this character: https://www.daz3d.com/mimi-hd-for-genesis-81-female
    She has made a second stage controller in Z-rotate.
    Last update.
    I uninstalled Mimi, which solved my issue.
    I will create a ticket.
  • extraneuxextraneux Posts: 31
    I'm having this problem too, you are a life-saver! How did you discover that Mimi was the source of the problem?
    Post edited by extraneux on
    After some initial trial and error, I found it as a general problem with G8.1F.
    Then digging a bit more I got a suspicion that it could be a controller, and disabling contollers for that rotation "fixed" it.
    Then looking in the Property Hierachy I found it, and could based on that see it was Mimi.
  • Here we are almost 2 years later and I just ran into this issue. Uninstalling Mimi 81 HD now. How has this NOT be fixed yet? If this is a known issue, the product should have been pulled from the store until it was fixed. Period. I know I bought this character in the last few months as I tend to kick the can down the road with this vendor as their morphs are a bit extreme. But I have found that with extreme characts that you just dial the morphs back to 40% or so and then you have a workable base with other morphs.
