Scene Info window/tab can't do simple addition? (Solved)
lukon100lukon100 Posts: 864
It says one scene has 1,627 verts.
So I put another copy of everything in the scene into the scene, and add yet another object to boot.
Then it says the scene has 2,976 verts. That is less than double the original amount. Why?
Post edited by lukon100 on
  • crosswindcrosswind Posts: 10,356
    If you correctly loaded the very same subset or 100% duplcated the selected items, the vertex count should be correct, i.e. x2 ... Maybe you can check the items again.
  • Anythng instanced?
  • lukon100lukon100 Posts: 864
    Richard Haseltine said:
    Anythng instanced?
    Nope:
    Cut to the chase: you can download my free model and see for yourself what I'm talking about.
    The dowload features 2 scene subset assemblies: the single and the double. Contrast the vertex count between them and see for yourself.
    https://www.renderhub.com/lukon/observation-deck-tetrapoint-base-v1
  • OmnifluxOmniflux Posts: 442
    You are not duplicating the elevator
    Single
    799 Observation Deck, V1
    012 Base, Small, Short, V1
    816 Elevator, V1
    1627 TOTAL
    Double
    799 Observation Deck, V1, Right
    012 Base, Small, Short, V1, Right
    799 Observation Deck, V1, Left
    012 Base, Small, Short, V1, Left
    816 Elevator, V1
    538 Bridge, V1
    2976 TOTAL
    Single
    816 Elevator, V1
    1627 TOTAL
    Double
    816 Elevator, V1
    538 Bridge, V1
    2976 TOTAL
    Yes! Thanks so much, Omniflux!
