pose preset or equivalent for a prop?
Sample shown is a vehicle used in a render in it's position for the scene.
I need to do some work on it so want to center it etc ... basic work position where lots of the mods I use are created so after I move it there is there a simple one click way to move it back to the position for the render?
Currently I would save it as a subset, reload it in a new scene, do the changes, create a new subset save it, open it in the original scene and align the x,y,z etc to match the original but that doesn't do the rotations for instance.
Now if it's just the vehicle it's easy to just line the old and new up and delete the old but since they subset often includes the characters, which will be moved etc or reposed, deleting a subset with vehicle, characters, does not happen quickly.
1252 x 775 - 298K
  • crosswindcrosswind Posts: 10,351
    Restore Figure Pose or Restore Selected Item(s) Pose... : Edit > Figure > Restore.... You can specifically Memorize the poses if needed: Edit > Figure > Memorize ...
    maybe I didn't read your answer correctly or didn't state the issue correctly.
    I want the pose shown in the image which is not the standard one
    which I would change the values on by centering the vehicle to zero.
    if I restore the pose on the vehicle will that restore it to the illustrated pose
    And does that require saving the current pose and can you save poses on a vehicle?
    edited February 2025
    Certainly... if you Memorize its Pose(s) as a "default pose" before further posing it and saving the scene subset. After loading the subset, you can restore it to its default pose at any time.
    The above way doesn't require saving a Pose Preset but you always can save Pose Preset(s) for easy use...
    Post edited by crosswind on
