The presets for Dark Wave Fantasy French hood don't work.
Even though I have no problem applying the materials individually, when it comes to applying the preset materials, I get this error message when attempting to apply them:
 Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
2025-02-12 13:58:26.256 [WARNING] :: Error loading asset: L://My DAZ 3D Library/People/Genesis 8 Female/Clothing/Dark Wave Fantasy/French Hood/French Hood Presets/DWF French Hood Preset 02.duf
Operation failed.
Can someone help me find out what I'm doing wrong here?
  • That eror happens if you use the item on genesis 8 and not an 8.1.
    The only 'fix' is to make new presets, or use 8.1.
  • crosswindcrosswind Posts: 10,251
    They're Hierarchical Material Presets that'll check if the Node Name of the selected figure is in line with the data saved in the preset files... however, G8F doesn't support G8.1F's Alias, that's why you got the error message.
    Before loading the H.Material Presets, select your G8F figure, go to: Edit > Figure > Scene Identification..., change Node Name from Genesis8Female to Genesis8_1Female.
  • Thank you guys so much!
