After updating, getting “Daz permission requests” a LOT...
Greeting, and thanks for any help anyone cares to offer!
Recently, I updated both the regular version of Daz, as well as the Public Build, both of which I run on my Mac Studio M1, OS: Sonoma 14.6.1.
Since then when I open them I get request permissions for acces to my Downloads folder, as well as my Documents folder.  Sometimes it asks for each once.  Sometimes, it will cycle through and before I can get to work, it will repeat the process TWENTY or more times.  UFFDA.
...Anyone have ideas why this is happenning?  I'm approaching being an interemediate user, but this has got me feeling NOOB alllll the way.  ..I. Just. Want. To. Work.!
Thanks for reading, and hope you have a pleasant and mindful day!
JD - Three Below Zero
  • ElorElor Posts: 4,101
    edited February 2025
    MacOS will be ask you each time you're launching the PB beta after using the general release and vice versa.
    But it won't ask if you're launching the PB after using the PB beta or if you're launching the general release after using the general release.
    edit : hum, I read too fast so what I wrote is how it should work.
    Post edited by Elor on
  • memcneil70memcneil70 Posts: 6,098
    Whenever I have an update to Daz Studio and DIM, no matter the version, Mac OS will double-check if the program may continue to have access to 'Files & Folders' and 'Full Disk Access' under Privacy & Security in System Settings. That is what that message is asking you. Check your settings and see if Daz Studio's access has been turned off. I also have given Daz Studio, DIM, and DzInstalHelper access to Accesibility to control my computer. I also double-check these after an OS update. I have found them turned off at times.
