Karen 7 - materials currpted in Iray! (solved)
Hello!
I have downloaded all my content with DAZ Connect. Using DAZ 4.9
Every time I load Karen 7, I get the results that you can see in the image below. The face texture does not fit the rest of the body. Or is it the head? Something seems to be currupted here. Of course I use the Iray materials, and it does not matter if I use a different makup. The result is always the same.
Does anyone else have the same problem with Karen 7? What can I do?
1000 x 1500 - 410K
Post edited by XoechZ on
Are you using the Legacy materials or the ones without a qualifying word? The legacy are for DS 4.8 or 4.7 (if they show in the Connect download at all). I can get a similar mis-match by applying the Legacy preset and then a makeup preset, but that follows the bounds of the Face surface - which goes up to the top of the skull, not to just above the brows.
Are you using the Legacy materials or the ones without a qualifying word? The legacy are for DS 4.8 or 4.7 (if they show in the Connect download at all). I can get a similar mis-match by applying the Legacy preset and then a makeup preset, but that follows the bounds of the Face surface - which goes up to the top of the skull, not to just above the brows. If that is the issue (if the diffrent boundary is because you have split the Face surface, for example) then reapply the legacy preset after doing anything else (or don't use it, since it is for an earlier version of DS before nVidia fixed an Iray bug).
I am using the material without "Legacy". And I get this bad result just by applying the "all maps" material, without any makeup. And if I add makeup, the problem does not go away. And I do not split anything (do not even know how that would work). I simply load the figure and apply the material.
All other figures work perfectly, only Karen 7 does not.
OK, that is odd - I really don't know what could cause it. The files in the Connect download should be the same as those in DIM, which is what I was using.
You are right. Especially because the broken seam does not match the face texture seam. Very strange. I think I will try to uninstall and re-install her. If that does not help I will write a support ticket to DAZ.
Ok, reinstalling her has solved the problem! So I think it was simply a corrupt or broken download.
Thanks for your assist.
