Adjusting shading of Toon Shader
I can usually fix this, in Surfaces/Emission Color.  But this 'Toon Brick' shader doesn't seem to work that way.  I usually get the darkness/shadow effect, when I swing the item around, but have not reset Emission Color- ...which generally (after adjusting a few other things) comes out the way I wish.  But this Toon Brick shader remains dark.  Is there another setting that will keep the surface lit up? (It only does this when the item- like a wall, in  this case- is swung around, of course.  And the surface- the brick- can no longer be seen in pre-rendor state.)
346 x 502 - 7K
  • crosswindcrosswind Posts: 10,341
    Go to G9 Starter Essentials, load Basic Filatoon Environment into the scene firstly...
    2560 x 1392 - 3M
  • dash2128dash2128 Posts: 736
    Thank You!  That seems to have done it!  This is the first time I used a toon shader.  And the first time I noticed so much toon in G9 Starter.  I'm having some cute characters walk into a place that turns from a normal environment, to a kind of (halfway) toon environment.  So I went with the toon brick.  And used mesh grabber to twist it up a bit.
    416 x 498 - 40K
