will daz come up with alternative tools like 3dxchange? anyone use akeytsu?
Will daz come up with alternative tools like 3dxchange? (export to other soft like unreal, unity, modo, max, maya, c4d, lightwave, blender,...)
'm thinking of buying 3dxhange for quick bhv editing (motionbuilder to high and don't like autodesk at all) and it export to unity, unreal....,  i don't really need iclone as it's to low poly stuff for me, it have physX with sprite creation (softbody) another feature 'm still missing in dazstudio.
Anyone use akeytsu animator?
just played with "akeytsu" and love it! Dazstudio still have no real good solution to do animation becaeuse of the ik problems, but for now it seems i need 3dxchange to make the rig usefull for dazstudio.
so would it be best to go for 3dxchange now or some kind of alternatives expected soon? now with the launch of morph3d...
  • Can you elaborate a bit on what features you are looking for?  You can currently import BVH files into Daz, then export an FBX with animations that Unity can import.  Are you looking for more options on the BVH import?
    If you haven't tried it already, KeyMate greatly improves the keyframing experience and is a good way to clean up imported BVH animations:
    http://www.daz3d.com/keymate
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,655
    edited February 2016
    You need iclone to use 3Dxchange and pro at that to use pipeline that exports
    it will not work without iClone installed, everything greyed out.
    want a universal tool, get Ultimate Unwrap 3D and all its plugins, most of the common ones work in 64bit the more obscure things like Bethsada nif need 32bit
    it polyreduces nicely too
    and does UV mapping of course too
  • wolf359wolf359 Posts: 3,955
    I use Iclone Pro 5.5 with the 3D exchange pipeline tool to retarget iclone created motion to genesis and poser native rig via 3D Exchange 3D exchange will import BVH rigs from outside sources(such as poser) or FBX rigs from MAX,,Maya etc. Ultimately All of my Character animations are rendered in Maxon Cinema4D Via Obj /MDD( For genesis) and BVH ( for poser via interposer pro for C4D). Understand however that 3DXchange is designed to quickly retarget "Imotion" files created within Iclone itself to rigs imported from other applications and all of the really useful Character motion generation tools and the vast Character motion library presets are in Iclone Do not be put off by the low poly, native Iclone figures they are game res so you can easily get realtime, viewport feedback when creating complex character motion with the incredible tools of Iclone. However the true power is being able to RETARGET that motion from those low poly Iclone people to hi quality figures Like genesis or other application native rigs ( MAX Maya etc)via FBX or BVH through 3D exchange.
    Post edited by wolf359 on
  • Fixme12Fixme12 Posts: 589
    yes i know keymate, nothing wrong with it better as basic timeline. the main problem remains the unworkable Ikinematics of main studio.
    for the animation problem i can start use nukeygara akeytsu and quick set good ik to the mesh rig, very promising for animation until daz come up with straight solution in the main studio program.
    the problem is, that you first need to take the fbx (re rigged) true 3dxchange to make the rig back useable for in dazstudio.
    huh,  how can i fix a rig setup...,  with a uv mapping tool?
    Also make sure you get the free key culling script by casual It's called "decimator". For DS It is vital for reducing keyframes of BVH for easier editing with graphmate& keymate.
  • I thought you mostly wanted to get DAZ stuff into other software, it will do that
    things like directX and ogre as well as many others, I cannot give a commercial link but you can Google it
    retargetting ikinema is used by some, I myself use 3Dxchange as I use iClone
    a shame actually that this script is not in the main program as quick temorary solve fix.
    what do you think of this workflow?
    https://www.youtube.com/watch?v=2N-uAS0xS0Y
    so you get the animation in iclone,  and if i remember well, you can import iclone animations back in studio, not
    Post edited by Fixme12 on
    3D File Formats
    Description Extension Import Export
    Alias Wavefront OBJ yes yes
    3D Studio 3DS yes yes
    3D Studio ASCII ASC yes yes
    3D Studio Max ASCII ASE  yes  yes
    AutoCAD DXF  yes  yes
    Cinema4D C4D  yes  yes
    Collada DAE yes yes
    Google Earth KMZ kmz
    Truespace COB yes yes
    Autodesk FBX FBX yes yes
    Lightwave LWO yes yes
    Lightwave Scene LWS  yes
    Luxology Modo LXO  yes
    Sketchup SKP yes yes
    Microsoft DirectX X yes yes
    Microsoft XAML XAML    yes
    SoftImage|XSI XSI yes yes
    AC3D AC yes yes
    Anim8or AN8     yes
    Artlantis Studio AOF,ATL  yes
    Away3D AWD yes yes
    Blender XML  yes
    Blitz3D B3D yes yes
    BioVision Hierarchy BVH yes yes
    Celestia Space Simulator CMOD  yes yes
    Cartography Shop CSM yes yes
    DarkBASIC DBO  yes yes
    3D GameStudio MDL  yes yes
    Genesis3D ACT, BDY  yes
    Goo Create zip,bundle  yes
    Leadwerks Engine GMF,MDL    yes
    Metasequoia MQO  yes yes
    MilkShape3D MS3D yes yes
    Nichimen Nendo NDO yes
    Ogre 3D Engine MESH, XML  yes yes
    OpenGL CPP CPP    yes
    POV-Ray RAW RAW  yes yes
    POV-Ray POV POV    yes
    Rhino 3D 3DM  yes yes
    SpaceEngine Space Simulator SM yes
    Torchlight - Runic Games MESH  yes
    Torque Game Engine DTS, DSQ yes yes
    Unity Javascript JS    yes
    Apple Quickdraw 3D 3DMF     yes
    Adobe Illustrator AI yes
    Hollywood FX HFO  yes
    ATI NMF NMF yes yes
    Stanford Polygon File Format PLY yes yes
    Stereo Lithography STL yes yes
    Object File Format OFF yes yes
    VRML 1.0, 2.0 WRL    yes
    Extensible 3D X3D     yes
    Battlefield 2 staticmesh  yes
    Battlefield 1942 SM, RS yes yes
    Black & White L3D yes
    Call of Duty 1/2/4 xmodel  yes yes
    Command & Conquer: Renegade W3D yes
    Descent 3 OOF  yes
    Delta Force 5: Black Hawk Down
    Delta Force 4: Task Force Dagger
    Delta Force 3: Land Warrior
    Delta Force 2
    Delta Force
    3DI  yes
    Diablo 3 APP, ANI yes
    FarCry, Crysis CGF, CAF yes
    Freespace 1/2 POF yes
    Half-Life: Opposing Force
    Half-Life 2
    Team Fortress 2
    MDL yes
    Half-Life 2
    Team Fortress 2
    SMD yes yes
    Homeworld PEO, GEO yes
    Homeworld 2 HOD yes
    MikuMiku Dance PMD,PMX,VMD,VPD yes
    MotorRacer 3 F3D yes
    Mount & Blade: Warband BRF yes
    NetImmerse Format/Gamebryo
    Dark Age of Camelot
    Freedom Force
    The Elder Scrolls V: Skyrim
    The Elder Scrolls IV: Oblivion
    The Elder Scrolls III: Morrowind
    Sid Meier's Civilization IV
    NIF yes yes
    Neverwinter Nights MDL yes yes
    Quake 1 MDL yes
    Quake 2 MD2 yes yes
    Quake 3 Arena MD3 yes yes
    Return to Castle Wolfenstein MDC yes
    Kingpin: Life of Crime MDX yes
    Quake 1/2/3, Half-Life BSP yes
    Doom 3 md5mesh, md5anim yes yes
    Wolfenstein: The New Order bmd6model yes
    Heavy Metal: FAKK2
    Medal of Honor: Allied Assault
    Medal of Honor: Allied Assault Spearhead
    Medal of Honor: Allied Assault Breakthrough
    SKB,SKD  yes
    Shogo: Mobile Armor Division
    Blood 2: The Chosen
    Aliens vs. Predator 2
    The Operative: No One Lives Forever
    Global Operations
    ABC yes
    League of Legends SCO,SKN,ANM yes
    Lula 3D
    Psychotoxic
    V3O, VMO yes
    Orbiter Space Flight Simulator MSH yes yes
    4x4 Evolution SMF yes
    Rainbow Six Rogue Spear QOB, ROB yes
    Rome: Total War CAS yes yes
    Empire: Total War
    Napoleon: Total War
    variant,rigid yes yes
    Runescape DAT yes
    Sonalysts Combat Simulations
    Jane's Fleet Command
    Sub Command
    Dangerous Waters
    J3D yes
    Strike Fighters 1/2
    First Eagles 1/2
    LOD yes
    SWAT 3: Close Quarters Battle GSM yes
    Tread Marks LUV yes yes
    Re-Volt PRM yes yes
    Serious Sam MDL yes
    The Sims SKN, BMF yes yes
    Second Life BMP yes yes
    Birth of the Federation HOB yes
    Star Fleet Command 1/2 MOD yes
    Star Trek Armada 1/2 SOD yes yes
    Star Trek Legacy M3D yes
    Star Trek: Voyager - Elite Force MDR yes
    Jedi Knight: Dark Forces 2 3DO yes
    Jedi Knight 2: Jedi Outcast GLM yes
    Star Wars: Empire At War ALO yes
    Star Wars Battlefront 1/2 MSH yes
    Star Wars Battlefront 3 (pre-alpha) RAX yes
    Star Wars Battlefront 2015 meshSet yes
    Star Wars Galaxies MSH, MGN yes
    Star Wars: Starfighter MSH, MDL yes
    Supreme Commander 1/2 SCM, SCA yes yes
    Unreal Tournament 3D 3D yes yes
    Unreal Tournament PSK/PSA PSK, PSA yes yes
    Vampire: The Masquerade - Redemption NOD yes
    Watch Dogs XBG yes
    World of Tanks
    World of Warplanes
    World of Warships
    primitives
    primitives_processed
    yes
    StarCraft 2: Wings Of Liberty
    StarCraft 2: Heart of the Swarm
    StarCraft 2: Legacy of the Void
    M3 yes
    Warcraft 3: Reign of Chaos MDX yes
    World of Warcraft
    WoW: The Burning Crusade
    WoW: Wrath of the Lich King
    WoW: Cataclysm
    WoW: Mists of Pandaria
    WoW: Warlords of Draenor
    M2, WMO yes
    Worldcraft MAP, RMF  yes
    2D Graphics File Formats
    Windows Bitmap BMP
    Truevision Targa TGA
    Microsoft DirectDrawSurface DDS
    JPEG 2000 JP2,J2K
    Joint Photographic Experts Group JPG
    Portable Network Graphics PNG
    Zsoft Paintbrush PCX
    Adobe Photoshop PSD
    Adobe TIFF TIF
    Pixar Image Format PXR
    Portable Pixel Format PPM
    Portable Grayscale Format PGM
    Portable Bitmap Format PBM
    Radiance High-Dynamic Range Format HDR
    Diablo 3 TEX
    Serious Sam TEX
    Descent 3 OGF
    Homeworld LIF
    Call of Duty 1/2/4 IWI
    Jedi Knight: Dark Forces 2 MAT
    Rainbow Six Rogue Spear RSB
    LithTech Shogo/Blood2/AvP2/NOLF/GOps DTX
    Warcraft 3/World of Warcraft BLP
    Thats one comprehesive import export list
    incidently I mostly use it myself for UV mapping and polyreducing
    it will polyreduce rigged animated FBX files
    but have stuck my Skyrim figures into Carrara fixed the bone hierarchy and then retargetted and animated them in iClone
    opened the odd freebie C4D rigged figure in it too and exported as FBX to Carrara etc
    but where talking about animation now, not uvmapping
  • DAZ has recently been posting new short aniMate 2 video tutorials on YouTube which are, I think, a little easier to follow compared to the old GoFigure tutes, which weren't bad. If you have keyMate, graphMate, and aniMate 2, along with Puppeteer, you have some pretty good tools. Build a bunch of reusable motions and you can do a lot in a very quick period of time stacking them where you want them in aniMate 2. I found a European tute which does a very good job of showing what can be done with the existing tools (I can't understand the language but it's pretty obvious watching it), and specifically using reusable motions and stacking them in layers. mcCasual's scripts can help with some problems as Wendy mentioned, but you can also use nulls to correct for some issues very quickly with minimum effort as shown in one of the new tutes.
    https://www.youtube.com/user/WWWDAZ3DCOM
    https://sites.google.com/site/mcasualsdazscripts6/mcjautolimb2015
    https://sites.google.com/site/mcasualsdazscripts6/tutorial-fixing-an-animate-walk
  • I give up cheeky I will just keep doing what I am doing, you just keep asking for answers
    it's called trolling :p  for uv's we use 3dcoat or modo so not need a uvmapper
    trying a pipeline between akeytsu animator and dazstudio and may be i need 3dxchange
    Yes Iclone can create excellent animation and supports Daz genesis directly to transfer the motion to genesis to render back in Studio.
    thx for reply, seems the 3dxchange is good for fbx between other platforms...
    until daz come up with it's own alternative for support genesis platform  in all other main 3d soft.
    another question,
    you can create spx (spring effects) to bones in 3dxchange after import in iclone at springeffect to it for movement.
    like: https://www.youtube.com/watch?v=Z8Mmn4M93nE
    now if you with your bvh motion from iclone true 3dxchange and back to studio, will this spring effect movement still be added to the meshrig or lost?
    another question,
    Hi, if the bones have animation data  in the timeline then any spring effects
    should export I assume
  • ArtiniArtini Posts: 10,935
    Akeytsu is on the sale http://store.steampowered.com/app/446060/akeytsu_Indie/
    Does anyone use it with Daz3D assets?
  • unLight865unLight865 Posts: 95
    You were also talking about getting the model from one softeware to another - and that's where UU3D is helpful as converter.
