Activity bar lost
Hi!
When I started DAZ this afternoon there was no activity bar. To klick on the activity bar entry in the window-worksapce menue showed the tab for a moment then it disappeared and there is a new tab "Advanced" where the activity bar shoul be.
Anyone any idea what happened? What can I have done wrong?
  • crosswindcrosswind Posts: 10,351
    "Advanced" is the default activity bar... press F3 (Window > Workspace > Customize...) to check if the activity bars you've ever defined are still there, under Activities tab.
    Then save a Layout in which the status of activies are saved. (in layout *.DSX file) Then relaunch DS to see if it works as expected.
  • paidpaid Posts: 43
    I never actively defined any activity bar (I used it as it came with the installation) and I can't find any in Customize. Also not only the activity bar disappeared, my favorites and scripts did, too. As if there was a kind of major reset. But why?
  • It sounds as if your layout fils were damaged - perhaps a disc error or security software - and so you ar enow getting the very basic version. You should still have Window>Workspace>Select Layout though, but the menus may not be in their usual order.
