Genesis 8M Loads With Other Settings
I've seen this discussed for other people, but it never happened to me.  I just reinstalled Studio et al. copying assets from my old iMac to a new Mac Mini.  Everything works pretty well once I got paths pointed to the right places, but have found that Genesis 8M is loading with Darius 8 body and head set to 100%.  I uninstalled and reinstalled Genesis 8 Male Essentials and Darius 8, but it is still happening.  Oddly, this does not happen on the iMac from which stuff was copied.
What's the fix for this?
  • SofaCitizenSofaCitizen Posts: 2,183
    Load up the base G8M figure, select it in the scene and click "Currently Used" in the parameters tab. You should see morphs relating to Darius 8 shown there with a non-zero value. If not then try clicking the top-right-corner menu and selecting Preferences -> Show Hidden Properties. Dial all morphs back to 0%.
    Then you can save this with File > Save As > Support Assets > Save Modified Assets.  In the save confirmation dialog it should list the morphs that will have their defaults set to zero - this should match the morphs that you altered in the previous step.
    I think that's all you need to do. If it doesn't work, try again but do Memorise > Memorise Figure before the save.
