Counting the polygons?
It probably sounds silly but after I updated to 4.23 I cannot find the tab where the polygons and the vertices were shown.
Please enlight me.
  • GordigGordig Posts: 10,822
    edited January 2025
    It seems to be part of the Scene pane now.
    491 x 110 - 8K
    Post edited by Gordig on
  • crosswindcrosswind Posts: 10,351
    You can right-click on the tab to Detach it, then drag it to where you want to place it.
  • Thanks, I found it.
    Which still doesn't respond to the question - why killing something which works (the old Scene info tab).
  • handel_035c4ce6 said:
    Thanks, I found it.
    You can split it to a separate pane if you wish (right-click on the tab>Detach), but reducing the number of panes needed is usually seen as a good thing - and this has introduced fucntionaility that can be used to add sub-panes to other panes too.
