How can you make skin move when touched?
Hello everyone!
I know have D-Former and I use it a lot but D-Former is circle and I want it to be like fingers , Any idea how to make it ? I want for example someone grab another person hand or like touching and make the feeling to be more real :)
Thank you very much! ^^
  • felisfelis Posts: 6,635
    When you have applied the dFormer,:
    * select the field in the scene tab
    * swith to Node weight brush
    * In Tool Settings add Influence map, and the area will turn grey-bkue-red
    * paint weights as you usually would
    Be aware there need to be enough geometry in the target object (a finger is usually small)
    Thank you first of all! ^^ I did what you tell me but in some option I didn't understand and try to search in youtube where this options are . for example I did the D-Former and  Node weight brush I find it , but then I didn't understand how to do it , I try to search in youtube some video on it but didn't find maybe because I don't write it well? you have any simple youtube video that I can follow or even images?
    edited January 2025
    I am not aware of a video using weightpaint on dFormers.
    There are tutorials on doing weightpainting, but couldn't find one right now.
    I made a screenshot, showing the essentials.
    If you can get to there you should be able to get an understanding of it.
    You paint with the mouse, and subtract by holding <Alt> while painting.
    1813 x 798 - 213K
    Post edited by felis on
    This is a video by Mada on weightpainting (here for dForce, but you weightpaint the same way).
  • crosswindcrosswind Posts: 10,356
    edited January 2025
    Case by case... though users have no way to create HD morphs no matter by using D-Former / Mesh Grabber / Sculpting, etc. but making grasp effect on a softbody by using collided mesh as initial shape + sculpting should be always better than only using D-Formers, let alone using D-Formers on such case will be cumbersome.
    Like the below example, make a basic grasp shape by turning on Smoothing + Collision on the target figure, reshape with Mesh Grabber or sculpt in Blender, you may get much better effect and this way is easier than using D-Former(s).
    2560 x 1392 - 2M
    2560 x 1392 - 1M
    2560 x 1392 - 1M
    Post edited by crosswind on
  • @felis @crosswind Thank you so much to both of you! It worked with your advice but at the end I bought Ghost Dynamic and it's perfect! Thanks for helping! :)
