action or script for repetitive task? part of a submenu?
alan bard newcomer
Side trip, one of the really neat things about the old (possibly new) excel is "ditto" function ... literally you can ctrl-" and it copys and pastes something from the cell above.
So I was resurfacing a model that came it as one piece and it overlaid itself in places so a lot of custom fitting using Geometry Editor
Basically a lot of selecting a poly or two and going right click for the mini-menu>geometry assignment>select surface>choose target
So the top of the menu above Tool Mode ... the option to click "ditto" or "repeat" ... do what you did to the last poly with this one
The current system has a lot of steps but alternately you don't have to move to a menu but just click next to where you are to get the dropdown.
This would be like when you click on something in windows and choose new folder delete copy paste etc.
Why can't you just multi-select more polygons before assigning them? Not that I can't see a "repeat assignment" command having benefits, but it does seem you should be able to reduce the pain without needing a new feature.
