Figure Metrics isn't working
I have been trying to use figure metrics since I purchased the measure metrics a few days ago. Every time I try to use it the whole app crashes/closes. I feel pretty sure I am doing eveything right because I followed all instructions and I even re installed eveything including the app itself. I tried using a Genesis 8 Female Body with the matching preset measurement nodes and figure metrics didn't work. The app crashed. Then, I tried with Genesis 2 Female Body along with it's matching preset measurement nodes and it worked the first time. I think. All of the measurements from the preset measurement node (the one with more than the basic measurments), most of those measurements there was no way for me to customize/change them. Only the basic measurements within that same preset had a box next to it that I could click to customize the measurements.
Now that I went back to try again, a few days later, even the Genesis 2 for figure metrics is not working at all now. The app insantly crashes. I am really upset by this because not only did I pay good money for the measure metrics, but I also really need to make an avatar with specfic/custom measurements. I know I am very new to all of this but I just need simple custom sized avatars. Can anyone help with this issue?
p.s. Everything is the latest version, since I downloaded everything not even a week ago.
The initial Figure Metrics does load with only a few measures assigned to modifiers - once it is working you can add more in the Advanced tab, but be wary of selecting competing properties to measures you will want to adjust.
What are your system details, and how are tou installing? Do you get a crash report or does the application simply vanish? Have you tried disabling third-party plug-ins to test http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/plugins/plugins_load_config/start
I'm using a MacOS 15 and I'm installing using the DIM installer. I get a report from apple when it happens. However, when I check the log files in the app it doesn't read anything about a crash. There is the last log of when I load figure metrics and then the next log is when I re open Daz. I have not tried disabling third party plug ins as I haven't heard of that. What plug ins would I disable?
