Problem To Carrara from Daz Studio 101 - Saving Millenium Dog with Puppy Shader
DiomedeDiomede Posts: 15,457
edited January 2025 in Carrara Discussion
Greetings,
Having a very basic problem.  Trying to keep file sizes small on my laptop.  I want to change the textures and morph parameters of the Millenium Dog available from Daz, which is in CR2 rigging format, and save it so that it loads directly to Carrara.  I have loaded the millenium dog in Daz Studio, adjusted the morph parameters, and applied a MAT pose preset from the millenium pup.  I have tried to save it as a scene, a scene subset, and a character preset, but none of those work.  Some won't save out of Daz Studio without changing weights, others give an I/O error when trying to load in Carrara.
I can load the millenium dog directly in Carrara, adjust the morphs, and apply the preset.  I was hoping to not have to do that every time I want to load.  Doesn't saving from Daz Studio reduce the file size?   Or am I mixing that up with later figures?
1414 x 856 - 189K
Post edited by Diomede on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,507
    you would likely need to save it as support asset figure AND make sure you have blended/triax weight too
    and no, it's a much bigger footprint than legacy Poser rigging
    I love using Poser legacy content in Carrara for just that reason, it works so well compared to duf which is full of issues
    another option is DAZcollada export from D|S Carrara import which works quite well with Poser content
    edited January 2025
    Thanks Wendy.
    I will just load it in Carrara directly, morph and texture there, and save natively in Carrara format.  blush
    Diomede said:
    Thanks Wendy.
    this applies to DAZ studio BTW too
    once you save legacy content as duf it creates a dsf data file under autoadapted and loading morphs not added before saving doesn't work well as it no longer has deltas etc the way Poser works
    Great info, as always.  Thanks.
    Embarrassing that I have forgotten such basics.
  • HeadwaxHeadwax Posts: 10,562
    how do you know all this stuff Wendy ?
    trying it myself surprise
    Ha ha life is short press hard!
