Increasing font size in Daz Studio
Is there a way to increase font size in Daz Studio?  They are so tiny I can barely see them and can't find any setting to change their size; meanwhile all my other apps don't have this problem.
  • As has been explained in various other threads on this topic, enabling UI scaling requires a  new version of the Qt framework which will break plug-ins. So it is not possible before the next major version of Daz Studio. The application does, on Windows, respect the OS font scaling.
    If you have one monitor then changing the resolution will make the type sizes larger.
    It seems that if you use multiple monitors that are not the same size you lose control of placement of panes on the second monitor because the system is tied to the main monitor or such.
    The bolded part is incorrect -- I am using it in Windows 11 with fonts scaled to 125% because I upgraded to 2560x1440 monitor resolution. Fonts are literally so small they are unreadable.
