Pose Converter is missing
Hi, I am having trouble installing one of the Premier tools which is the Pose converter. I've installed it on DIM but I go on Dazstudio and it's not under Edit->Figure->?
I've tried reinstalling the addon on DIM and restarted it on Dazstudio but no luck. It's not there.
Anybody had this trouble?
  • crosswindcrosswind Posts: 10,300
    You need to Login Daz Connect to verify your Premier tier firstly. Then you should be able to find it under Edit > Figure > Pose Converter
    If you still cannot find it, Window > Workspace > Update and Merge Menus
    982 x 877 - 110K
  • wintoonswintoons Posts: 393
    I've tried 'Update and Merge Menus' and it's still not there. :(
    1) If you go to Help > About Installed Plugins..., can you find this plugin enabled ? (ss1)
    2) Press F3 in DS, can you find it in the Action List on the left ? You can always manually drag it to Main Menu Bar... (ss2)
    669 x 868 - 74K
    1407 x 1255 - 135K
    Hi, Just to let you know, I've found them they were installed and I've added on them on my menu.
    Thanks Crosswind! :)
    Great ! NP~ yes
