Hair floating a few inches above the model's head
doorknob22doorknob22 Posts: 64
edited January 2025 in Daz Studio Discussion
Hi!
I have this problem with a specific hairpiece that when I render it the hair seems to float a few inches over the model's head, creating a rather disturbing result. Model is Krashwerks' Squeaky on GF 8.1. Any idea what might be causing it? I managed to get one good render but subsequent renders had the same problem.
  • felisfelis Posts: 6,503
    I don't see issues when loading it.
    You said it looked fine in one render, and then had issues in the following. Did you do something special in between the first and the following?
    If you look at currently used in Parameters, for the hair, what do you then see?
    And what happens if you delete the hair and reload it?
  • 1. No. Same DUF file.
    2. No parameters for the hair. I just load it and set a Mat to it.
    3. I tried deleting hair and reloading it. Rendered two test scenes with limited time of 600 seconds. Problem solved. Went through all the scenes in the batch and deleted & reloaded the hair, set their time to proper 5400 seconds and started Batch Render: the first render turned out with the same problem, but I'll leave the batch running over night.
  • Please remember not to post images with nudity (sorry for mising this, I could see she had some clothes in the thimbnails and hadn't twigged how sheer it was). For these you could have cropped the images at shoulder level to show the issue.
