Why do properties on the shaping tab show up as tiles?
zidra.lodenzidra.loden Posts: 115
edited December 2024 in Daz Studio Discussion
[Why do properties on the shaping tab show up as tiles?] More importantly, how can I stop it? I can't see the property names and only three tiles fit on the pane. I just want this tab to look like all the others - a list of horizontal sliders. Any ideas?
  • felisfelis Posts: 6,503
    I suggest adding a picture of what you are seeing, so people can know.
  • zidra.lodenzidra.loden Posts: 115
    Added screenshot(s). First is what I'm seeing, second is what I want.
    216 x 598 - 38K
    219 x 605 - 41K
    Post edited by zidra.loden on
  • DrunkMonkeyProductionsDrunkMonkeyProductions Posts: 1,311
    That's how it's designed to behave.
    There's no options to change it from tiles to list, that i can find in any menu.
    The reason it's only able to show 3 tiles, is that the tab is too narrow to show more.
    You can expand it by click-hold-drag on the Dock area divider.
    Post edited by DrunkMonkeyProductions on
  • BejaymacBejaymac Posts: 2,002
    You would need to manually edit the figures main DSF file to change it from the "cards" to sliders, and I wouldn't recommend trying it.
    Post edited by Bejaymac on
  • Richard HaseltineRichard Haseltine Posts: 111,370
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_23_0_5
    • Extended DzShapingPane scripting API; added isShowingPropertyCards(), setShowPropertyCards(), toggleShowPropertyCards(); added showingPropertyCardsChanged() signal
    • Added a “Show Property Cards” (DzSHPNGShowPropertyCardsAction) action to the “Preferences” submenu of the Shaping pane option menu
      • When enabled, regions of an object that are configured to display “cards” for properties, display cards
      • When disabled, cards are not displayed for any region regardless of its configuration
  • crosswindcrosswind Posts: 10,249
    Yea, DS 4.23.1.8 Public Build gives such a feature to disable "show cards" ~
    544 x 808 - 110K
  • lilweeplilweep Posts: 2,872
    use parameters tab instead of shaping tab...
