Texture problems with a character
I don't know who can help me. I bought this product a while ago https://www.daz3d.com/seb-hd-for-genesis-8-male
When I open it it tells me that some textures are missing. But I see them in the local folder. I put a sequence of screenshots on what the program says with the hope that someone can help me solve it.
977 x 919 - 756K
1018 x 616 - 414K
858 x 500 - 198K
1103 x 670 - 196K
1080 x 705 - 182K
  • felisfelis Posts: 6,577
    The actual file should be in the Runtime folder.
    If you look in the log Help > Troubleshooting > View Log, what is then the full text about the missing file?
    And how do you install content?
  • dannagiusy64dannagiusy64 Posts: 477
    edited December 2024
    Ciao, grazie per la risposta.
    Io installo sempre i prodotti con Install Manager.
    Non riesco a leggere il file di testo del log triste
    felis ha detto:
    Il file effettivo dovrebbe trovarsi nella cartella Runtime.
    Se guardi nel registro Aiuto > Risoluzione dei problemi > Visualizza registro, qual è il testo completo sul file mancante?
    E come si installano i contenuti?
    Post edited by dannagiusy64 on
  • Maybe this string has something to do with it?
    2024-12-21 21:16:56.719 [WARNING] :: \src\sdksource\cloud\dzcloudtasknotifier.cpp(201): Could not adjust thumbnail path from support path: /Runtime/Support/DAZ_3D_Belly_Dance_Nights_Outfit_Genesis_8_Female.dsx
    This should be the full path in your content directory
    • /Runtime/Textures/Emrys/Seb/SebEyesB_1006.jpg
    If you don't know how to read the log, then attached it to a post as a text file.
  •  In the Runtime>support folder there are the 3 product files
    txt
    txt
    log.txt
    1M
  •  Thanks for the reply, but aren't eyes the eyes?
    felis ha detto:
    Questo dovrebbe essere il percorso completo nella directory dei tuoi contenuti
    Se non sai come leggere il log, allegalo a un post come file di testo.
    1779 x 570 - 396K
    It is looking for the file in your Daz Connect library, as Connect takes priority.
    If you don't plan on using Daz Connect (installation from inside Daz Studio) then find the product in product view in Smart Content, right-click and select Uninstall. You might have to reinstall in DIM after that.
    If you not are using Daz Connect you do not need to log into Daz Studio, unless you are a Premier member.
  • Since I can't find the Smart content folder I uninstalled the product with DIM, then I reinstalled it but it gives me the same problem.
    felis ha detto:
    Sta cercando il file nella tua libreria Daz Connect, poiché Connect ha la priorità.
    Se non hai intenzione di usare Daz Connect (installazione dall'interno di Daz Studio), trova il prodotto nella vista prodotto in Smart Content, fai clic con il pulsante destro del mouse e seleziona Disinstalla. Potresti dover reinstallare in DIM dopo.
    Se non utilizzi Daz Connect non hai bisogno di accedere a Daz Studio, a meno che tu non sia un membro Premier.
  • I managed to uninstall with Smart Content and then I closed the program, I reopened it, the product does not give me any errors, but the skin has no wrinkles on the face or body, it has smooth skin
  • Thank you so much for your support. Maybe this is bettersorridente
    931 x 898 - 831K
    That you can load the textures is a good start.
    Missing wrinkles could be a missing normal map. Or it might be that you need to crank up sub-d - it is a HD character after all.
    Are you looking at an actual render or Iray preview? Preview will usually have lower subD. Maybe try to do a real render?
  •  Yes, thanks, that's right, the rendering is more detailed. What do you think? I made this very quickly
  •  The image was not attached to metriste
    1000 x 1000 - 437K
  •  Then I will have to improve the skin tone, I have to make the skin clearer and less shiny
