Alligator/Crocodile head morph for G8F
I see a lot of anthro models for G3-9M but theres a few ideas id want for G3-8F if possible. https://www.daz3d.com/lizardian-for-genesis-81-male are there any crocodile/gator head morphs for g8f for example?
  • GordigGordig Posts: 10,810
    Sobek has a crocodile head, but I don't believe the head can be separated from the rest of the body (and it's for G8M, but you can use morphs to get a more feminine body).
  • crosswindcrosswind Posts: 10,318
    edited December 2024
    Sobek is a nicely-made "crocodile man" and has quite a few alternative skin textures from FenixPhoenix.
    Alternatively, if you want to make a conversion... you can convert Sobek G8M to Sobke G8F by using Fit Suit method (method: https://youtu.be/jROlY34tNNU?si=CC8AxmyTFxdANfd6) as well as splitting Head and Body morph by using HeadSplit D-Former (method: https://youtu.be/nEFI6keXU2c?si=utxZnl2NF_cfas9Q) in G8 Starter Essentials. Tail goe-graft and Teeth can be re-rigged to G8F.
    Edit: But Sobek has a unique UV... you need to convert the texture maps from Sobek UV set to Base Female UV set by using Map Transfer. (method: https://youtu.be/YxE5Lfkid1M?si=aZYLObQ8UyWNx3ya)
    2560 x 1392 - 2M
    2560 x 1392 - 2M
    Post edited by crosswind on
