G9 loading with some male morphs
I did what I read to do to get rid of the weird morphs loading, and saved it after zeroing and saving the g9 character, but now I loaded G9 again and it loaded with the morphs but when looking at currently used there are no morphs there that were loaded now I am confused as before I could show hidden stuff on the parameters pane, and zero the figure and remember it, then save as morph asset. which I did now I can't even zero the figure. I don't know what to do if I knew what morphs it loaded I can fix it, but there are no morphs loaded that show up.
  • lilweeplilweep Posts: 2,883
    edited December 2024
    wow.
    Where is your information coming from?  What exactly did you save? All modified assets? You should be careful when doing that as some morphs should not be zeroed by default (which is what zeroing and memorizing all morphs will do)
    The option to zero figure will prompt you to restore or zero. Are you sure you are clicking zero and not restore?
    A screenshot and description of your problem would have been helpful.  As would punctuation. Maybe just upload your scene .duf file (with just base gen 9) and people can check if there is any active morphs in 'currently used'.
    Post edited by lilweep on
