why T-Rex break
in screenshot, my T-Rex model has broken apart. I dunno why or even if possible. How? Why? How fix?
don
1176 x 634 - 349K
    edited December 2024
    At a quick glance that doesn't look like it's broken as such, but maybe the surface of that section (torso?) is invisibile - i.e. check the opacity?
    Post edited by SofaCitizen on
  • crosswindcrosswind Posts: 10,351
    Press Ctrl + L firstly ,rotate the View in Viewport, see and post what you get...
  • dondrawdondraw Posts: 170
    did that, and result is unchanged:
    1152 x 576 - 478K
  • Literally looks like you merely have the hip/pelvis toggled to invisible. Try opening the scene pane, expanding the T-Rex (hit the little down arrow on the left) and make sure the little "Eyeball" next to the hip/pelvis is open (click the eye).
  • CES3DCES3D Posts: 258
    You're using "Tyrannosaurus Rex", right?
    As roni190 mentioned, if the "Hip" bone is hidden, it will reproduce the same situation you are experiencing.
    Please check if the eye icon of the "Hip" bone is closed.
    If the eye is closed, click it to open the eye.
    2560 x 1400 - 877K
