About pixel shading on model (have image)
Hello!
DAZ3D have an amazing models and the shading work AMAZING on them , But I decided to make some furry model and for some reason the model have shades like pixels as you see.
Have anyway to fix that or this is the model texture I just can change? Thank you ^^
If I can't it also looks amazing hehe looks like shading game but I prefer the real daz3d shading. ^^
569 x 391 - 437K
180 x 224 - 81K
  • crosswindcrosswind Posts: 10,351
    edited December 2024
    No need to touch the texture maps for the time being...
    1) Make sure your figure's Resolution Level is set as High Resolution, then set Render SubD Level to 3 (at least 2).
    2) Crank up threshold Values in Render Settings > Texture Compression. If you use DS 4.23+, set Off in Texture Compression.
    See if it is improved.
    Post edited by crosswind on
  • foxyfoxfurriesfoxyfoxfurries Posts: 394
    Hey! Thank you very much! I did the first one and add her 3 but still the shading the same , about the daz 4.23 I download it now and check it hehe
    I try them both and it's the same restults , maybe it something with the model then?
    Ohhhhhhh never mind it woooooooooooooorks! I did it on High Resolution and it works! I missed it! THANK YOU SO MUCH!
    Post edited by foxyfoxfurries on
    Yea, that's it ! If you notice those low-poly things shown in below screenshot, that means a Base Resolution ~~ smiley
    559 x 614 - 253K
    Your awesome! now it so sharp! Thank you now my model is perfect because of you! THANK YOU!!!! :)))
    341 x 878 - 561K
    620 x 599 - 795K
    405 x 560 - 408K
    No problem ! yes
