Issue with X-Fashion Basic Sport Lingere
Not sure how I should go about reporting this, happens with any character model and no character model.
613 x 738 - 240K
  • felisfelis Posts: 6,656
    This set I assume: https://www.daz3d.com/x-fashion-basic-sport-lingerie-for-genesis-9-and-8-female
    What does textured wireframe look like?
    And does it happen with the base character, and/or is the character posed?
  • crosswindcrosswind Posts: 10,359
    You may try chaging Smoothing Type to Generic... if there's a Smoothing Modifier on the lingerie.
  • ElorElor Posts: 4,272
    It seems to be visible on the main promo renders, but I don't think it's supposed to be here. Or maybe it's the spoiler, to get a better aerodynamic profile around the shoulders laugh
    On a more serious note, I would report it.
  •  no pose and any pose. here is g9 base feminine
    1180 x 1079 - 437K
  •  I do see it visible now on the promos.
    441 x 306 - 156K
  •  switching to generic seems to have fixed the issue for now, haven't test other than base model. I should still probably report it. It's likely unintentional.
    864 x 815 - 308K
    edited December 2024
    In most of such cases, the culprit is the problematic geometry on the edge. If you observe it closely, you should be able to find something wrong...
    When the collision is calculated on the mesh with Base Shape Matching as well as high value set in Smoothing Iteration, it'll collide to a  "bulge" or something like that.
    Generic type usually helps. But you still can report the issue by filling a ticket if you'd like to.
    Post edited by crosswind on
    Victoria 9 is supposed to be among the supported shape but there is no file taking care of that with her name (or the name of any of the Genesis 9 figure supported) in the readme, only FBM for a couple of Genesis 8 figures:
    http://docs.daz3d.com/doku.php/public/read_me/index/106481/file_list
    They are possibly some files missing somewhere.
    Hmm... have you noticed that under the data folder of G9 top/bottom, there're supportive FBM files for Victoria  (as well as for others)... but just with wrong names for V8. Not sure if they work... but if they don't, that was really wrongly-defined.
    840 x 271 - 44K
  • So is the manner to report things normally to file a ticket?
    Filling a ticket is usually the right way ~
  • Okay, I will do that. Thank you all for your help and consideration.
    I tested it and dialing it manually, nope, it's not a Victoria 9 morph disguised as a Victoria 8 morph laugh
    Looking at Victoria9_body_bs_Body (no idea what it means), I'm the 'author', meaning it's an auto-generated one.
    1358 x 829 - 127K
    Post edited by Elor on
    You're right, haha ~ In this case, thi issue cannot be simply fixed by re-configuring the ERC link because the FBM morphs are not correct per se.
    Fill the ticket !  yes
    Yea, Victoria9_body_bs_Body is just the blended body morph of V9 coming from G9, auto generated on the Top by Auto Follow. So you're the Author.wink
    It took a bit more time than I thought, but I finally had the time to fill a ticket regarding this problem. Hopefully it can be solved soon.
  • omvendtomvendt Posts: 231
    I purchased the XF lingerie bundle, but when I want to install it on the G9F that comes with Daz, it closes the character
  • Richard HaseltineRichard Haseltine Posts: 112,078
    Install or load and apply to the figure? I assume the latter. Which X Fashion set - I am not immediately seeing an X-Fashion Lingerie Bundle, and if it is a bundle it presumably contains more than one item.
    edited July 2025
    According to a message the Daz Support Team just sent to me, a fix was deployed related to the ticket I subtimed around the launch of the product. I have no idea if it's in any way related to @omvendt's problem.
    Back then, not knowing if an update would be provided or not, I asked for a refund before the 30 days window ended, planning on getting the product back once a fix was deployed: right now, I don't have the product to check if the update is completly fixing the problem, but in case people have it, read this message and didn't find the time to fill a ticket, they should check DIM.
