How to make a light from inside the object and cast shadow on the surface?
Hi there,
I'm trying to make a Native American tent(tipi) with person inside and a source of light. The camera is outside so expected result is to cast the shadow of that person on the surface of the tent.
I was experimenting with lights and material opacity, glass shader, etc. What I'm thinking about is a shader (caustic) or something like that but I'm not experienced enough so any ideas or suggestions are very welcome.
  • This is handled by translucence - are you rendering in 3Delight or Iray?
  • linvanchenelinvanchene Posts: 1,386
    edited February 2016
    You made me curious how that works in Iray.
    Made a quick test scene with
    - a cone
    - G3F Starter Essentials
    - Default Lights and Shaders - Fabric Velvet Red
    Diffuse Weight set to 1
    Translucency Weight set to 0.5
    The .duf with the test scene is attached as a .zip
    1920 x 1080 - 452K
    zip
    zip
    Iray Tent flat wall v1001.zip
    279K
    Post edited by linvanchene on
    3delight
  • @linvanchene
    Awesome! Many thanks! I'm going to play with it, yay :)
  • SzarkSzark Posts: 10,634
    To get translucency in 3delight use Uber Surface which should be under Shader Presets > omnifrecker > Uber Surface. To apply shader hold Ctrl (CMD for Mac) down when applying shader and choose to ignore replacing maps.
  • Many thanks !
    1280 x 720 - 1M
    1280 x 720 - 842K
    which render engine did you use as it turned out well.
    3Delight - always
    LOL
  • Szark said:
    LOL
    The reason is: rendering time. I have one HP workstation Z230 with:
    • HP Z230T – Intel Core i7-4790 – 3.6 GHz Processor
    • 16GB ram
    • HP NVIDIA Quadro K620 2GB Graphics
    • 1TB 7200 RPM hard drive
    I was testing Iray with GTX960, 16G RAM and A6 6400K 3.9GHz CPU and the rendering time was tooo long, more than 30 minutes per frame so for 3 min animation 30fps would take 2700 hours or 112 days.
    Trying Nviadia Cloud Rendering failed, it won't work easily with Daz3D and there is big buttle neck: each frame is around 200MB so it is around 1.08Tb - how to transfer quickly that amount to remote server?
    So I decided to go with CPU rendering only as is lower cost comparing to GPU.
    Now, I have network drive with frames(RIBs) and workstation with Puppy Linux(30% faster than windows) and 3Delight processing each frame around 3 minutes or less - acceptable
