INSTALL BRUSHES TO PHOTOSHOP USING DAZ INSTALL MANAGER
I HAVE A ROUGH IDEA HOW TO DO IT, BUT I COULD REALLY USE THE STEPS.
I wish to instal Cyber Ciurcut Brushes and Ron's Space Brushes into Photoshop, but I'm not sure what path to use.
I've attached a snapshot of the mesage I get, in the Install Manager.
What path and steps to follow to install these brushes in Photoshop?
496 x 389 - 61K
496 x 389 - 61K
  • barbultbarbult Posts: 27,497
    edited February 2016
    You need to tell the Daz Install Manager (DIM) where to install content for Photoshop. You do that by clicking on the Settings Gear icon in the upper right corner. Then select Applications and click the + to add an application. Select Photoshop from the drop down list and fill in the information about where your Photoshop is installed. Then you should be able to install the brushes with the DIM.
    736 x 948 - 248K
    Post edited by barbult on
  • dash2128dash2128 Posts: 736
    THAT WORKED, THANK YOU!
    All I had to do was locate the correct path fpr Photoshop, and follow the directions you gave me.
    Great! Glad it worked out for you.
  • cja92cja92 Posts: 0
    (My 1st ever comment in the entire forum.) Thank you Barbult! Finally, PS product installation is a success!
