How do I paint the UV Map of G9 Ivee?
3dGordon3dGordon Posts: 43
Hi, I want to paint over the pink coloring in the Gen area, to make it look like the surounding flesh color.
I tried finding the Map necessary, but this map does not have the pink coloriing, so there must be another map.
Thank you very much. ;)
Post edited by 3dGordon on
  • I am guessing it is the SSS map that might be causing the extra pink. Normally in the translucency area.
  • Please don't post texture images, unless they are all your own work.
  • crosswindcrosswind Posts: 10,249
    edited December 2024
    Attaching nude images is allowed now ?
    Post edited by crosswind on
    I think you painted on the wrong map (if you just painted on the texture maps of Torso or Body of Genesis figure.... ). You should've painted on the texture map of anatomical elements or the "color shell" on it... depending on which genital product you use ~~
    Only when I get distr5acted by another issue. Fixed.
    yesdevil
