Photoshop backgrounds/actions
Hi,
I'm new to using Daz 3D and have many questions.  First off, I have bought some photoshop backgrounds/actions (http://www.daz3d.com/downloader/customer/files/prod/23103) but am unsure how to use them?  How do I import or load into PS?
Thanks.
Oakmist
  • Product link http://www.daz3d.com/pin-up-backgrounds-poses-and-expressions
    The images can be used as backdrops in Daz Studio (via the Environment pane or by applying them to a plane primitive) or in Photoshop (as new layers in front of or behind the render layer - render to png or tiff so that you get transparency or a saved mask to isolate the areas with geometry). The actions need to be loaded into Photoshop using the Action pane's option menu, and then applied by running them (possibly with a correctly set-up document, I don't have the set so I'm not sure on that).
  • Thanks very much Richard yes
  • Where are the pin-up backgrounds installed? I'm not able to find them.
  • HylasHylas Posts: 5,347
    Did install with DIM?
    Right-click on the installed product and select "Show Installed Files"
  • DazCentral
