dforce Combat suit V missing files?
I'm not sure if it's only my install (installed via DIM) but the "dforce combat suit V" product from SWTrium seems to be missing a lot of stuff. In fact only empty thumbnails appear in the lost and found daz folder, and I found only legging-related stuff in the relevant data folder (see attached screenshot).
If it's not just me how and where I can report it?
https://www.daz3d.com/dforce-combat-suit-v-for-genesis-8-females
  • crosswindcrosswind Posts: 10,356
    Yes, it's just because this product has no metadata. This product originated from Rendo site but when it was brought to this store, Daz gave no metadata to it before releasing to the store. You may fill a support ticket but I'm afraid you won't get answer... as far as I know from the situation of other similar products...
    I bought this product from Rendo and I installed it by using Content Wizard so everything is fine. If you want to have it in Smart Content, you can either install it with Content Wizard or by using the action of Create a Product from... in Content Library
  • CES3DCES3D Posts: 262
    I also purchased that product.
    I don't see any particular problems in my environment.
    I am installing via DIM.
    Have you tried reinstalling it?
    2560 x 1400 - 941K
  • felisfelis Posts: 6,630
    You will notice that none of your icons has a label 'Wearable', 'Material', etc meaning it is not categorized. And if you look in the database it will not have comptability and comptability base, so you can't find it in Smart Content  if you filter by context.
    Yes, I understand that.
    daer-thing is saying that Lost and Found only has empty thumbnails for them, so I showed them that I can call up the products from Lost and Found without any issues in my environment.
  • daer-thingdaer-thing Posts: 91
    edited December 2024
    Hey, thanks for the reply.
    Yeah tried to reinstall it a couple of times. Here is how it looks like in my smart content pane: (1st attached pic)
    And the window popup I get when I try to apply !Full Set Combat Suit V on Genesis 8: (2nd attached pic)
    In file explorer I can see where it is installed but that folder doesn't appear in my content library.
    Ninjaedit: tried to install it manually, into my custom "My library" custom library and it seems to be working now O_o;;;;;
    478 x 652 - 63K
    402 x 98 - 9K
    Post edited by daer-thing on
  • The exclamation mark in the frame means that theer is no thumbnail for the file, the exclamation mark in the corner means there is no file. If the path doesn't appear in your content library goes /data/cloud/1_#####/ then that is, as expected, the Connect install. Uninstall that (by right-click on the product in Daz Studio) and you should be able to use the Install Manager files, assuming your paths are set up correctly.
    Thanks! Doublechecked everything and the problem was the "content base path" remained the default in DIM. Reinstalled DAZ yesterday on new computer and in Advanced settings/Installation I made a custom path for where I keep my content but didn't delete the default one and somehow it remained the base path. blush
    Turns out other freshly installed stuff had the same problem I just didn't notice yesterday.
