Is there a way to get clothing to interact with other clothing in a simulation?
Reality HackReality Hack Posts: 111
[Is there a way to get clothing to interact with other clothing in a simulation?]Like the sweater over this dress, for instance.
Thanks in advance.
1562 x 1076 - 1M
  • felisfelis Posts: 6,563
    When doing simulation dForce objects will interact (do collision check) with any other object in the simulation. But to avoid intersecting it requires that the object don't intersect when the simulation starts.
  • CES3DCES3D Posts: 255
    Enabling Mesh Smoothing on the outer clothing and changing the Collision Item from the character figure to the inner clothing can sometimes yield good results.
    If you want the Collision Item to be not just "one inner clothing" but "the character and inner clothing" or "multiple inner clothing", you can export and import them together to make them a single object, and then specify that object as the Collision Item. This should work well.
    2021 x 1275 - 840K
    2022 x 1277 - 1M
    2020 x 1275 - 1001K
    2021 x 1274 - 764K
  • Much better. Thanks.
    Although it did take four-and-a-half hours to simulate on my 3070. But I think that may have just been because I did it in-scene.
    1024 x 1024 - 1M
  • crosswindcrosswind Posts: 10,342
    Four-and-a-half hours ? with a Timeline for animation ?
