Iray Renders Black
Trying to use Enchanted forest by Stonemason but Iray just wants to render black.Anyone else run into this issue or know how to tweak the settings to make it work properly? It has a sky dome in it and I've always had trouble with scenes that have sky domes.
    Ditch the skydome...Iray doesn't need it.
  • Thanks, okay I have it rendering normal now but when I go to use the light set I bought from Dreamlight that is doesnt render correctly if I ditch the extra skydome that they have in there. Removing that causes the scene to render all the same on the three different types of lighting choices but leaving it in makes it render black or way too dark. Is there a way around this?
  • FishtalesFishtales Posts: 6,233
    Try changing the camera settings in Tone Mapping to let more light into the 'lens'.
    Either lower the f stop; lower shutter speed or raise the ISO, or a combination of all three :)
    Your advice fixed the same problem for me when trying to render DT Yosemite ... Thank you!
