[CLOSED] DzVec3.dot return allways a positif number which is wrong
Hello, i need to know if 2 vectors are in the same direction. So i use the dot method from DzVec3 and it returns allways a positif number even if the two directions are opposite.
example:
DzVec3(38.1018,13.0803,-117.265).dot(DzVec3(0,106.945,0.342321) )
return: 1358.727294921875
it must return -1358.72
thank
Post edited by darkdesire on
Are you sure? I get the same as script calculating long-hand.
Using your vector and antiparallel vectors of my own gives the expected result in scripting:
print ( DzVec3(38.1018,13.0803,-117.265).dot(DzVec3(0,106.945,0.342321) ) );
print ( DzVec3(1,1,1).dot(DzVec3(-1,-1,-1) ) );
gives
1358.73046875
-3
oups,
made a big mistake. It works, didn't verify the vector orientation in my test. sorry all is good
