Improving DAZ Studio Rendering Quality & Times
I use an MSI GeForce RTX 3050 graphics card, which can produce washed-out whites and overly-bright highlights when I use Iray and infinitely long render times I'm obliged to use 3Delight. Would upgrading to the MSI GeForce RTX 4060 make an appreciable difference? Or would I get the improvements I'm seeking with a different render engine? There is in this marketplace a free Octane Render Kit that seems to promise advanced render options. Has anyone any thoughts on this matter? Much thanks to one and all.
  • felisfelis Posts: 6,630
    Check Burn Highlights and Crush Black values in render settings. At least in the latest beta the default values have changed.
    That said an RTX 3050 has 6 GB and VRAM, and that can fast be used, so you only can use CPU for rendering, so a GPU with more VRAM will be better.
    You can look in your log Help > Troubleshooting > View Log if your GPU runs out of memory.
  • Thanks for yours, felis. It is appreciated. I'm thinking it's time for a better G-card. I've forgotten when I installed the present one.
