Startup Crash using Public Beta 4.23.0.4 (Mac Version)
ever since I updated the Default Resources for 4.23+ on DIM 3 days ago, the public beta build will always crash upon start up for the Mac. Not sure what the issue is, but it's driving me crazy lmao.
  • mcorrmcorr Posts: 1,104
    You could:
    (a) Deinstall all he default resources. Fire up Studio again and see if that solves the issue, and if yes, add individual pieces back (one by one) until you find the offending piece. Then remove it and see if things are running again.
    However, I would suggest a more thorough approach:
    (b) Before you do (a), make sure that when you installed the default resources (or before that), you didn't also install plugins, since they are usually the source of problems (especially at start up). If you installed any, remove them first  ... then add them back one by one as described above, and see if that takes care of the problem.
    If that hasn't solved the problem, then proceed with (a).
  • mcorr said:
    You could:
    Okay, so it turned out that the Daz to Blender and GoZ plugins were the main problem and removing them fixed the issue. I appreciate your help here !!
