Object transforms change in timeline without keys
in The Commons
Hi all,
I'm getting quite frustrated here. I've been spending long hours setting up a room that will become the default setup of a scene. It's a lot of kitbash trying to decorate it. I've been doing everything at keyframe zero and deleted any other existing keys (except for zero) in the timeline. However, when i move in timeline some of the objects move around or change scaling. In the timeline preferences, I selected all the properties types including others and hidden and deleted every key I could see. I checked up to key 1000 just to be sure.
What else can i try or do to fix this?
Thanks in advance
Never mind. I fixed it. But still don't understand. Looks like at some point I assigned some transformations at a key different from zero and somehow it was reverting back to those values when a set the timeline to that keyframe, even though I deleted the keys. Still clueless but is fixed.
You sure you had selected all nodes when removing the keys?
