(SOLVED)dForce BS Bob Hair for G9 auto-fit to G8 problem
AsuCafeAsuCafe Posts: 520
Two questions about "dForce BS Bob Hair for G9".
1.When I use smart content and check "Filter By Context", it does not appear.
2.When I use auto-fit to G8 and then selecting material will show "Error"
It works fine on G9.
I have tested several G9 hair, and only  "dForce BS Bob Hair for G9" causes problems.
How to fix it?
LOG:
 [INFO] :: Prepare asset load (merge): /People/Genesis 9/Hair/BirthStone/BS Bob Hair/Materials Iray/Hair Color/BS Bob Hair Color 10 Red.duf
 [INFO] :: Locking viewport redraw...
 [INFO] :: Viewport redraw locked.
 [VERBOSE] :: Native format content directories: 2
 [VERBOSE] :: Poser format content directories: 2
 [VERBOSE] :: Other import format content directories: 0
 [INFO] :: Begin asset load (merge): /People/Genesis 9/Hair/BirthStone/BS Bob Hair/Materials Iray/Hair Color/BS Bob Hair Color 10 Red.duf
 [INFO] :: Determining missing assets...
 [WARNING] :: Invalid hierarchy for selected node(s) and "preset_hierarchical_material" type; no root(s) found.
 [WARNING] :: Error loading asset: E:/DAZ 3D/Studio/My DAZ 3D Library/people/genesis 9/hair/birthstone/bs bob hair/materials iray/hair color/bs bob hair color 10 red.duf
Operation failed
 [INFO] :: Unlocking viewport redraw...
 [INFO] :: Viewport redraw unlocked.
Post edited by AsuCafe on
  • The materials are Hierarchical - they look for a Gensis 9 as the base of the hierarchy. You could load a Genesis 9 and parent the hair to it for applying materials (no need to change the fit to).
  • AsuCafeAsuCafe Posts: 520
    Sorry my English is not good, it took me some time to understand what you mean, There is such a magical method, thank you.
  • crosswindcrosswind Posts: 10,249
    Alternatively another simpler way: select your G8 figure, change its Node Name to Genesis9 via the menu : Edit > Figure > Scene Identification.
    Then apply hair Material Preset with G8 figure selected or the hair node selected ~~
    582 x 319 - 26K
    Another magic, thank you !
