Studio 4.9 and GenX
I was in the middle on transfering some morphs with Studio 4.8 when I downloaded 4.9. I thought I would end up having both side by side. Unfortunately I don't and I don't have 4.8 to install back to my computer. So has anyone been able to use GenX in Studio 4.9? If not, does anyone know where can I find 4.8?
Thanks.
  • thd777thd777 Posts: 946
    GenX works fine for me in 4.9  I just used it. What problem do you run into?
    TD
  • BurstAngelBurstAngel Posts: 768
    edited February 2016
    It keeps telling that it can't find the clone to help it transfer the morphs, I wonder if I need to redownload GenX add-ons through the cloud or with install manager? not sure which.
    Post edited by BurstAngel on
    Which transfer did you try? I just did one from G2F to G2M without problem. I did not redownload anything since installing 4.9. If you want to try a redownload I would use either manual or DIM. All my current pulg-ins were installed manually.
    TD
  • CybersoxCybersox Posts: 9,913
    Are you using GenX or GenX 2?  They can't be installed at the same time and it's possible the older version got reloaded.
    I was trying to transfer to genesis. I do know it should be genx 2.
    Okay, It works with GF2, so I guess my issue is trying to transfer morphs to genesis.
