Installing "Tiler Shader for DAZ Studio"
First the product doesnt appear in Smart Content, under Available. I unchecked "Filter by Context".
This also is the case with G3F Body and Head Morphs btw.
So usually a workaround for this is to install the already purchased product from the store. This workaround did function on G3F Body and Head Morphs.
But this time "Tiler Shader for DAZ Studio" event cant be installed from the store.
As solution I tried to "Install Offline Products" from the Right Click on Smart Menu. But it failed also. Only a small window appears shortly and then disappears.
Any solutions?
510 x 280 - 15K
Post edited by Harry_2964 on
There are some things that can't be installed from the Connect content, you will either need to use DIM or manually install them. Shaders are possibly one of those items (I don't have a list and I'm not sure where the list of items that can't be installed with Connect is...it's in one of the long threads on Connect).
I found out that all products can be installed from the content library.
