Strange Happenings with G9 Morphs!
Hello! I am hoping someone might be able to point me in the right direction here. So, when I apply pretty much any morph for G9, it comes out... well... strange. Take a look at the picture I attached - that strange man is supposed to be Vicky 9! As you can see, there are no other morphs loaded in except Vicky 9 and the naval/mouth ones that automatically loaded in with the figure.
I tried searching for hidden morphs but found nothing. I tried zeroing the figure's shape, but it doesn't fix the issue. I went through every visible option available to me but didn't find anything.
Any help is appreciated! Thank you!
2096 x 982 - 213K
  • On the parameters menu go to the top and under preferences there will be an option to "Show Hidden Properties" check that.  You can then look for something that is being used under the currently used section.
  • crosswindcrosswind Posts: 10,356
    edited November 2024
    Vicky 9 Head / Body morphs were made with G9 Base Anime Head / Body ~~ obviously you've not dialed Base Anime morphs ...
    Better load Vicky 9 character preset from the product rather than manual dial the morphs.
    1678 x 1114 - 657K
    Post edited by crosswind on
  • Sorry, I didn't see they were the anime ones ... I am tired
