Filatoon render How to change the outline?
Hi all,
I'm playing around with the Filatoon render, and I'm wondering how to change the behaviour of the outline:
I know I can adjust the thickness using the geoshell mesh offset, but I was wondering is there also is a setting to make more (or less) of the outline show up.
I know the outline requires space between geometries to show, but for example on the ear: all of that is one piece of geometry, so mesh offset is not going to cause more or less outline to show up on the ear.
Yet the ear has lots of "sharp" angles that would (in case you actually drew the drawing by hand) cause an artist to put an outline on certain edges. The Filatoon render does not appear to do that... or can we tweak it?
Is there a setting to make the outline more dominant? (or less dominant)?
Thanks a lot!
you could try asking here
https://www.daz3d.com/forums/discussion/704951/anime-toons-and-filatoon-shader-q-a#latest
but alot of basic what does this slider do questions I'm finding it difficult to pin down. There doesn't seem to be a comprehensive guide anywhere.
Although I think some PA's are planning on pay for tutorials at some point.
