Premier locked - interactive licenses?
The new Lycan 9 looks awesome, exactly what I need. However the feminine shape addon is locked behind premier exclusive, which means I don't see any wat to buy an interactive license for it.
I kind of need it, my game has both male and female werewolves, after all.
Is it included if I got the interactive license for base Lycan 9? (Yeah, wishful thinking I know, I'm just trying to figure out a solution here.)
  • Cris PalominoCris Palomino Posts: 13,024
    The female Lycan is indeed a Premier exclusive, so you'd have to be a member and have access while you're a member.
  • PancakePancake Posts: 90
    edited October 2024
    Does that mean I'd have the right to use it for interactive license purposes too, if I export it to unity while a member?
    I can buy an interactive license for Lycan 9, but can't see any way to specifically buy it for the female addon.
    Post edited by Pancake on
    edited October 2024
    i believe so, but will enquire. {mod edit: Daz has said that Interactive and 3D Print licenses will not be available for Premier-Exclusive content - see https://www.daz3d.com/forums/discussion/704811/premier-membership-faq-questions-only-please#latest )
  • scorpioscorpio Posts: 8,533
    You ONLY have access to the character WHILE a member if at any time your membership ends then presumably your game will no longer work.
    Thanks very much
  • WolfwoodWolfwood Posts: 998
    Daz has said in de Q&A that they are not planning to add interactive license to Premier Exclusive content. So, legaly, even if you stay in premier you are not allowed to include the mesh in your game.
    I am a member, but don't see how to add it. Just type in the code?
  • frank0314frank0314 Posts: 15,114
    There is no code to enter. You just need to refresh your metadata for the exclusive products. ATM they are working on an issue with it not showing in people's accounts.
    That's worrying, if they're going to lock such important content as an entire sex for a species behind exclusive content that can't be used for interactive licenses.
    I wouldn't mind paying for them seperately like Lars and Nikita, but a female werewolf shape being locked behind premier only with no interactive license option  more or less guarantees there will never be a female counterpart with interactive license capability.
    Hopefully Cris Palomino will come back with some clarification after enquiring. (and hopefully there's some good news)
  • zombietaggerungzombietaggerung Posts: 3,954
    edited October 2024
    G9 is unisex. Couldn't you just dial in the default G9 female shape onto the male Lycan? Then you wouldn't have to worry about liscencing another figure shape.
    Post edited by zombietaggerung on
    I'm considering my options there. Was hopoing to have a difinitive answer before purchase though. I suspect what I might (MIGHT) be able to do is apply the base masculine G9 morph as a negative, thereby reducing the inherent masculinity.
  • nonesuch00nonesuch00 Posts: 18,878
    Not being able to use Premier in Interactive Content although I have one for DAZ Originals it problematic, but so far, nothing I'd can substitute something I can use easily enough has been released.
  • ArtAngelArtAngel Posts: 2,096
    Happy Halloween to all. Can someone please confirm or deny the following? I have read the appropriate info on Premier and my understanding is that the free Premier exclusive offerings and usage licenses for such, are on loan for as long as one is a Premier Member. Should that membership end, items that were no-cost Premier exclusive, are revoked and no longer accessible to use. However paid items purchased during a Premier Membership, are accessible if and when a Premier Membership terminates. Is this correct or incorrect?
  • LeanaLeana Posts: 13,614
    That’s correct, you will lose access to premier-exclusive content (like Aiko 9, the dark Elf shape for Vicky 9, the female Lycan shape) and premier plugins, but the rest is regular purchases (including the free bundle you get with the coupon).
    That is correct.
