My Daz has majorly crashed.
So I was working on DAZ afew hours ago and everything was fine. Now when I tried to used it, I can't load any of my characters from Genesis to Gen 8.1. It seems it can't find Data files? I checked all my directory paths and they are as they should be for the external drive that I use. I've tried re-starting and re-booting several times.
826 x 751 - 101K
901 x 778 - 104K
880 x 780 - 99K
928 x 400 - 69K
892 x 655 - 79K
  • Update: So these furry characters load with no problems, I guess because they are Hiro 3 and Aiko 3 base.
    859 x 784 - 113K
  • felisfelis Posts: 6,628
    How are you installing?
    And what is the full error text from the log (Help > Troubleshooting > View Log File) for one of the missing files?
  • This is part of the TS log.
    2024-10-30 12:16:23.137 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:24.736 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:24.741 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:24.773 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:24.777 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:24.789 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:24.819 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:24.836 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:25.082 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:25.113 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in categoryGetRoot: Unable to connect to the database
    2024-10-30 12:16:25.474 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
  • 2024-10-30 12:16:26.534 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetBySubdir: Unable to connect to the database, can not quote
    2024-10-30 12:16:26.536 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetBySubdir: Unable to connect to the database, can not quote
    2024-10-30 12:16:26.554 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetBySubdir: Unable to connect to the database, can not quote
    2024-10-30 12:16:27.621 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in contentGetByRelativePath: Unable to connect to the database, can not quote
    2024-10-30 12:16:35.606 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in CloudFIle::lookupFromDb: Unable to connect to the database
    2024-10-30 12:16:36.029 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in needMigrate: Unable to connect to the database, can not quote
    2024-10-30 12:16:36.107 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in runNextTask-runTask: Unable to connect to the database
    2024-10-30 12:16:36.177 Migration failed.
  • mostly, I've installed products manually.
  • Is the F: drive still connected, and still connected as F:?
  • Ok....now I see something confusing.
    So I have two externals connected to the computer and both are showing F: drive.
  • no....excuse me on that previous post. I have two externals and F: is showing twice?
    508 x 295 - 17K
  • sorry....Am I misreading the previous?
    Seriously though.....what if I clean out all of this and redo it from scratch?
    892 x 655 - 79K
  • Can you access files on the F: drive? For example, try opening a texture file from somewhere in /Runtime/Textures/ in an image editor.
  • Yes.....Using "Paint" I was able to open six files from Runtime / Textures
  • OK, so it isn't that the drive is failing at least. Are you sure that the content loaded OK initially - that is, if you work with Daz Studio online has it shown signs of downloading files when you try to open a newly installed product?
  • Are you sure that the content loaded OK initially - that is, if you work with Daz Studio online has it shown signs of downloading files when you try to open a newly installed product?
    So far, I haven't had or seen any downloading of files when I opened a new installed product to the point this morning when this issue started. It was working fine until I turned the laptop off to go to work and when I started DAZ then....I got the CMS alert and the problems started.
    I have had a problem though for the last month where Genesis 8 and 8.1 figures won't load properly.
  • could it be my firewall or virus protection blocking access to data?
  • What about DSON cashe? Could the port number be wrong?
  • Wow.....I just re-started DAZ a few minutes ago and it works again. Now I'm just having to re-map textures when the figures load up and show a missing textures box. I don't know how it re-set itself.
  • Thank you Richard for your trying to help me with this issue.
    What I might have done which could have solved this issue was this....
    On my external F: Drive there's two folders....
    1. USER
    2. USERS
    both contain CMS / DOSON files.
    So I switched the CMS from the current setting of USERS to USER and of course DAZ replied that it would not work well with that setting. I backed out of DAZ, re-started the lap top, went back into DAZ and selected CMS back to the USER folder.
    and things returned to normal.
    I would recommend everyone using external files to have saved back up folders for all their DAZ settings just in case you have this happen to yourself.
