Pose tweak in Animation
Hi there! Absolute beginner at animation in daz. I bought a couple's animation that's fairly basic, however a couple of the limbs need adjusting to avoid clipping. What is the easiest way to do this so that the adjustments carry forward through the animation? Is there a way to do that? Is there a guide anywhere that would be relevant to me learning how to manage this lol
  • Are they animated poses or AniBlocks?
    To my knowledge, they are animated pose presets
  • If you select the bone(s) you want to adjust and open the Timeline pane how dense are the markers, indicating explicitly keyed values? If they are fairly sparse then editing shouldn't be too bad, if there is a tick on every frame then it is likely to be more challenging because you will have to tweak every frame value in the range you wish to adjust.
  • crosswindcrosswind Posts: 10,244
    Recommend using this powerful script from mCasual https://sites.google.com/site/mcasualsdazscripts10/mcjcyclefilter2023
    You can recreate keyframes as well as re-interpolate values in the keyframe range with lots of options / functions after tweaking rotation values on joints of limbs ~~
