DAZ 4.9 update and can't see ANY Content
I just got the upgrade to DAZ 4.9 and now cannot see any content in Smart Content Pane or in Content Library.
What is up with that?
What do I need to do to get my content back and to view it.
Side bar...what is DAZ Connect, haven't seen anything on that.
What does it do and do I have to use it?
Thanks
  • LeanaLeana Posts: 13,621
    4.9 uses different tables in the database and when you install it it needs to fill the new tables from the old data first, which may take time. Check if it's still in progress, you should see something like "Converted X of Y items" in the lower left corner of the DS window if it is.
    DAZ Connect is a new system that enables you to install your content directly from within DS. You don't have to use it unless you have bought some products that are available via connect only.
    FAQ is here: http://www.daz3d.com/forums/discussion/65509/daz-connect-faq/p1
  • leo04leo04 Posts: 414
    edited February 2016
    Thanks, but not seeing what your talking about. Ran the Database Mantenace but that did not seem to work either.
    Any other ideas?
    Still attempting to update the DB...
    Post edited by leo04 on
  • Blackbirdx61Blackbirdx61 Posts: 300
    Having exactly the same problem, DAZ 4.9 is not migrating my old data just gives an Error Message. Nor can I log into DAZ Connect. Log in Fails even though I am using the same Password I updated an hour ago and used on the IM to down load this patch. As per DAZ remains the most frustrating app I have ever used.
    BB.
